Resolved! Solved
disable camera shutter sound
(Topic created on: 03-01-2020 05:20 AM)
beingnikhilahir
I m using samsung galaxy s10 lite.
How can i disable camera shutter sound?
2 Solutions
Not applicable
please click on 3 dots on my first coment on the top right hand corner and "Accept Solution" 🙂👍
Not applicable
you dont have to delete posts in future
12 Comments
You can't. But you can mute System sound to disable it.
there is such no option to turn off the shutter sound bro, you'll have mute your device 🙂
Not applicable
Go to settings -> sounds and vibration-> volume and then disable system sound
SliceSupport
Yes You can mute the shutter sound
using bixby routings
or install Good lock app and open routines
than set it as follows
settings are
CONDITION : 1. LAUNCH APP Select the camera
2. Action : click mute
Bro, there is no official way to turn off camera shutter sound..only option is to mute your device sound or system sound
or
second most effective method is the use of Bixby routines
I am using that to mute camera sound while taking photographs
Not applicable
bro why did your bluetooth post?
Not applicable
arogya sethu app was using it right?
yes bro
Not applicable
