camera problem
(Topic created on: 11-25-2020 04:25 PM)
royalmariner
I am facing problems with samsung s20 plus camera all photos are blurred . Some time its ok but most of the time picture quality is worst. Any guide to rectify this problem ?
8 Comments
gautam20
Me too facing same problem
johnnie12
after clicking photo don't move your phone just keep like that for 1 sec ..... you may get better photo
royalmariner
even after doing this getting same result
Ehsank
once open camera >settings >reset settings close camera and again open and try if not worked then do visit service centre
royalmariner
thanks buddy will try it n update
royalmariner
i think i have to visit service centre
GOPINATH-R
me tooo
cs-member13
Expert Level 4
Dear Samsung Member,
Please be assured and perform following methods to resolve the Camera quality issue:
1. Please clear data or cache of Camera Application(Tap Settings>Apps>Camera>Storage>Clear Cache/data)
2. Check device in safe mode - Using Safe Mode on a Samsung phone allows you to force the device to run the essential operating system, and disable most 3rd party applications.
To enter in safe mode: Press and hold the Power key, when Power off icon appears>Press and hold the power off icon.
To Exit safe mode: Restart the device.
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
