Camera problem
(Topic created on: 01-08-2026 09:37 PM)
recro
I have problem with my camera where selfie and front fell different and low quality of image while my brother and me have same phone s25 ultra with same configuration
6 Comments
SM-M055F
Samsung has some issues in their camera app
cs_member10
Dear Samsung Member,
● Kindly check physical condition of your camera lens.
● Kindly clean the camera lens by microfiber cloth or a cleaning wipe. Gently remove the fingerprint, dirt and dust from the camera lens.
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password, then advise to reset (Forgot password) your Google account.
Path: Settings> General Management>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update it's maybe fix by Samsung team soon. If you like please accept it's as a solution it's help to other users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
recro
I dont get any error
recro
Like their is not problem as camera working perfectly fine but the quality if quite different in my brother and mine like my camera image is dull but not my brother camera image
