camera problem
(Topic created on: 02-13-2020 03:32 PM)
Nomee
7 Comments
PunitVerma
that's not a problem, it's a Floating shutter button for ease. You can turn it off by going in Camera settings - Shooting Methods and turn off Floating Shutter button.
Nomee
dhanwad veere
Bro, that's called Floating shutter button..turn that off..
or
simply drag it back and merge with the main camera shutter button..problem solved..
NOTE: Even if floating shutter button is off..you can use it for your ease..simply tap on main camera shutter button and drag it anywhere on camera UI..it will help you to reach shutter button with ease and when not required drag it back to the main camera shutter button
Nomee
dhanwad veere
Bro, if problem solved then click at 3 dots near punit and my (above) comments and accept it as solution to help others 👍🙂
bro that's not an issue, you have activated floating shutter button
Bro, you have to click at 3 dots near our above solved comments and accept it as solution, so that others can get some help..👍
