battery stuck at 83 percent.cleared cache but problem still persists
(Topic created on: 05-18-2018 10:18 PM)
AkshayVarma
During charging using stock fast charger battery percentage gets stuck at 83 percent.cleared cache still the problem persists
5 Comments
RV0910
battery will be change
AkshayVarma
There is probably a software issue. Don't be an idiot
BhanChand
Dial *#0228# and reset battery
AkshayVarma
I tried again with wiping cache and it worked and charged fully. I've used it for some time and battery is now at 91 percent discharging. Should I use you method now or when this problem reoccurs. Please elaborate on how to and when to use your method
admin_
Thanks for being a part of Samsung community. We would like to inform you kindly follow the steps below to resolve your concern:-
- Navigate to apps >> Settings >> Apps >> Tap on three dots >> Reset app preferences.
- Please check with Samsung original charger.
- Please run your device in safe mode.
- Please do reset your device on factory mode after taking the data backup Via Smart switch.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
