battery drains fast
(Topic created on: 08-17-2022 08:03 PM)
VIJAV
Samsung people do not understand what kind of update they give without testing, the battery drains quickly, it is so hot from above, it seems that it will explode in s21 ultra, fix this problem quickly
3 Comments
Not applicable
It's the same for all android OEMs. They don't test thoroughly before releasing the updates. Most of the time, they give updates just to keep their commitment.
VIJAV
well said
cs_member8
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
