battery draining faster on S23 after one ui 7
(Topic created on: 05-01-2025 10:59 PM)
avipan
battery is draining faster on S23 after one ui 7.
I have to charge my phone twice or thrice in a day now. Before 1 charge was enough.
11 Comments
Nilesh_Shah
Many users are reporting same.
Look in the forum and see if any responses are of your help
CipherChip
I had same problem, because of major update ,I performed factory reset.
I did the same, my battery is good now , I charged my phone to 100% in morning and my battery still show 63% .
lf you find this useful, then click on the three dots given above this message and accept it as a solution.
thisisartman
When did you get the update? Generally, after any update, it takes a week for the battery life to stabilize.
avipan
just 3 days ago
thisisartman
Then wait. The way Adaptive Battery works is that it studies your usage patterns. Every update cleans your patterns since they make changes to how things work. That requires recreating those patterns. So, I'd recommend waiting atleast another week before jumping to conclusions.
What's your average battery life prior to the update?
avipan
4.5 hour screen on time
thisisartman
And what's the total battery duration? On a single charge, how long would it usually last? For example, my usage is pretty intense, so my average screen on time is around 8hrs, but screen off is also 11hrs.
I am still on OneUI 6.1.
The day I had 3+hrs Screen On, I had almost 13.5hrs total usage.1746294948129.jpg
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
avipan
that's **bleep**
