Resolved! Solved
Wifi network issue in S22 ultra
(Topic created on: 02-24-2025 01:27 PM)
Kumarsir
S22 Ultra vs S8 Plus wifi speed test 😢😢
goodthings
5 Comments
goodthings
goodthings
Your's most welcome to here.
Kumarsir
Thank you sir for your valuable suggestion 🙏🙏❤❤
goodthings
Your's most welcome.
cs_member10
Dear Samsung Member,
● Check Settings: Do you get any error pop up, on connecting your device to a Wi-Fi network?
Note: Any prompt that says "Authentication Error" is related to an incorrect password. Please contact your Internet Service Provider for assistance regarding changing your Wi-Fi network password.
● Forget the Network: Settings>Connections>Wi-Fi>Wi-Fi network> Tap and hold the Wi-Fi network that you're having trouble with until the menu allows you to select Forget Network.
● Reset Network Settings: Settings>General Management.>Reset>Reset Network Setting.
● Restart the Router and Mobile Device: → Switch off your Router (at the wall or with the power button on the router) and wait for 2-3 minutes before switching it on. While you're waiting, press the Power button on your mobile device and select Restart.
→Once the router has been successfully connected to the internet again, try to connect to your network on your mobile device.
→ Make sure there is no interference between the router and your mobile device. Concrete walls, fridges, and microwaves can all interrupt the Wi-Fi signal.
● Disable flight mode:→ Kindly check and disable the Airplane/Flight Mode on your device.
→Check Flight Mode by swiping down notification panel on your device with two fingers to access all of the Quick Settings.
→Find the Airplane/Flight mode option and turn it off.
3. If you do not remember the password advice you to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
