Wifi Speed Issue
(Topic created on: 10-31-2023 03:11 PM)
Pavank99
Hi I got my S23 ultra 3 weeks back.. Wifi is too slow on my device which I found out today when I ran speed test on my old device and new s23 ultra.. Anybody plz help
3 Comments
AdityaSheth
Try connecting to the different WiFi and if it does not improve, Take it to the service centre!
cs_member10
Dear Samsung Member,
Forget the Network: Settings> Connections> Wi-Fi> Wi-Fi network>Tap and hold the Wi-Fi network that you're having trouble with until the menu allows you to select Forget Network.
Kindly reset the network settings. Settings> General Management> Reset> Reset Network Setting.
Switch off your Router (at the wall or with the power button on the router) and wait for 2-3 minutes before switching it on. While you're waiting, press the Power button on your mobile device and select Restart.
Once the router has been successfully connected to the internet again, try to connect to your network on your mobile device.
Make sure there is no interference between the router and your mobile device. Concrete walls, fridges, and microwaves can all interrupt the Wi-Fi signal.
Kindly check and disable the Airplane/Flight Mode on your device.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs. Please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Please check my post, maybe it's the same issue.
