Wide Angle Camera Issue on S21 FE & S21 Plus (Exynos)
(Topic created on: 05-22-2025 10:43 AM)
Arbaz7222
Beginner Level 4
Hi,
I'm using the S21 FE (Exynos) and facing an issue where the wide-angle camera freezes or lags whenever I switch to it. The main (1x) camera works fine. This issue started in One UI 6.1 and is still there in One UI 7.
My friend with the S21 Plus (Exynos) is also facing the same problem. We’ve already tried clearing the cache and even did a factory reset (on the S21 Plus), but it didn’t help.
The issue occurs even in a cool environment and worsens when the phone gets warm.
Please provide a solution or update if this issue is being worked on.
5 Comments
goodthings
Arbaz7222
Beginner Level 4
Thanks for the suggestion successfully submitted the report lets wait hopefully it will be resolved
goodthings
Your's most welcome.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, you have already done the possible troubleshooting steps and the issue remains unresolved, we kindly request that you visit our service center. Our technical team will be able to inspect your device physically and provide you with detailed information and assistance.
You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
