Why battery capacity show less than full capacity in battery status in s20 fe 5g
(Topic created on: 11-29-2023 10:38 PM)
ivin200
Hello all,
In my new Samsung S20 fe 5G snapdragon 865 version full battery capacity is 4500 mAh, but in samsumg member app under phone diagnose battery status discription 4370 mAh shows. Is battery full capacity 4370 mAh or 4500 mAH. (Screenshot attatched below)
Is there any defect in battery? Please check your samsumg phone, is your phone also has same type of discription? Please help
10 Comments
This battery is tested to get certified by BIS Department ends only
Typical batteries are designed like that every phone have some reduced mah battery
TechyKamal
No, there's no defect. The actual battery capacity is 4370mAh only.
ivin200
Is this type of capacity in your phone??
TechyKamal
Yes. I am also using S20 FE 5G
ivin200
Is it low capacity shows in discription in your s20 fe,, please check and confirmed me,,, thanks
TechyKamal
I didn't understand what you are asking😅!
ivin200
Sir, i am asking that does in your s20 fe has the some amount of less bettery capacity in discription part where i have made red circle mark in my attacment...i m just request u to check in your phone samsung member app,,, hope u understand now🤔
TechyKamal
Understood now😅
Check the attached screenshot. My battery health has also degraded from Good to Normal.1701364125817.jpg
