Volume panel position
(Topic created on: 02-02-2021 11:59 AM)
joechristo
After I updated to one ui 3.0 in my s10e the default volume panel is showing on left. Is it the same for others?How do I change the position to right?
One ui 3.0 Volume panel
22 Comments
no it comes to the right of us
wait let me see how u can do that on the right
tell me do you use good lock...or try to move things here and there
it might have happened due to that
joechristo
before the one ui 3.0 update I was using sound Assistant volume panel theme with right as position
Now, there is option to change its position
IcyJay30
Expert Level 4
Sound assistance app will help... its straightforward
joechristo
but that changes the volume panel theme.
IcyJay30
Expert Level 4
Option to display left or right is there
