Voice focus mode not in Call UI screen
(Topic created on: 04-27-2025 07:37 PM)
BILLUSASI
Like One UI 6.1 voice focus mode not in Call UI kindly refix it
5 Comments
85PhoeniX95
It is just shifted to your control center, earlier samsung used to show it at both places but as customer said about the accidental touch they completely removed it from call screen and kept it as it is in the control center
BILLUSASI
Yes already i used that option..but it is very convenient to switch
PGUIN
when calling go to control centre left side
cs_member10
Dear Samsung Member,
As per your query, we want to inform you that this feature focuses on the sound, while you are on call with someone. When you are on a call with someone, a Mic icon will come with the calling number, you need to click that number, and your voice focus mode will be on.
ravimule
Its not there on One Ui 7.. we have to go to notification panel to change it. 🤔🙁
