05-17-2025 11:49 PM in
Galaxy S- Mark as New
05-18-2025 12:05 AM in
05-18-2025 01:03 AM in
05-18-2025 10:21 AM in
05-18-2025 10:22 AM in
05-19-2025 02:44 PM in
Galaxy SDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given link.
● Galaxy device vibration issue: https://www.samsung.com/in/support/mobile-devices/solutions-for-when-your-galaxy-phone-wont-vibrate-...
→ Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
→ You can reset your device by following the steps.
