UI 7 battery drain
(Topic created on: 05-12-2025 10:57 PM)
Thamlas
Has anyone experienced quick battery drain since the new update? How can I fix this?
21 Comments
Yes 🔥
Everyone has the same issue
dmugabe
Yes
ADeon
Beginner Level 3
Yep send the feedback on support so they can log it. Hopefully an update will fix it
Thamlas
Thank you, sir.
MSilva
Beginner Level 5
Yes, Battery draining fast and phone getting hot on Fold 6
Yaddly
Hi, on what device are you running UI 7.0?
Munatsi399
Which device did you have
Yaddly
I have S22+. I have deferred the update until the battery drain issue is resolved.
