Sumsung S20 FE 5G Battery draining issue
(Topic created on: 02-04-2022 03:50 PM)
Swaroop18
I recently purchased Samsung S20 fe 5g. After updating to Android 12 /One UI4 Battery draining very fast.
 85% to 20% not last for 8hr with below average use.
60hz refresh display mode on ,Extra dim on ,Adaptive battery on, no location, dark mode is on,
Sync on.
Battery protection is on.
Overall enabled all bettery saving options, expect power saving mode.
85% to 20%:
85% to 34%
Need help to extend battery life
29 Comments
Swaroop18
Yes it's basic math i know, I am a normal user and android 12 has battery drain issue, many reported same issue in community you can check.
Ab_Heartsy
Expert Level 3
Hmm...if you r a normal user, then ur battery is a issue. Maybe it'll resolve once samsung release a fix for it in February maybe 🤔. Meanwhile on days u want more battery for emergencies etc just charge it 100% n use it normally.
Swaroop18
Ya thank you for your input.
But charging it 100% is not good for battery life , hence samsung also give bettery protection option .
20% to 90% charge cycle is idle for good battery lifeScreenshot_20220204-180933_Device care.jpg
Ab_Heartsy
Expert Level 3
Oh... I said when on special n important days like job related or going on a trip/vacation ..where you want your phone to be with you always having full or close enough charge to last a day, then having 100% charge is okay, like once in a while 😊🤗
Swaroop18
Now I got context, thanks for
Explaing your actual tought.
Venu_G
85% to 34% that is 49% of battery use and you have got SOT of 3h 55m that is a decent battery according to me.
And this is the first update of One UI 4.0 so there would be bugs and issues always, wait for another update which will resolev these issues.
No need to worry, Above Average Battery life.
Swaroop18
Thank you for your input
cs-member13
Expert Level 4
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
Jaykeshariya
Facing battery drainin issue..any tips ?
save battery in samsung
go to setting
1. sound and vibration then system sound then off all vibration
2. notification then app notifications and off all unnecessary app notifications
3. display than on dark mode
4. display than off adaptive brightnes
5. advanced features than labs off all experimental feature
6. advanced features than motion and gesture off all
7. on power saving mode
