Sumsung S20 FE 5G Battery draining issue
(Topic created on: 02-04-2022 03:50 PM)
Swaroop18
I recently purchased Samsung S20 fe 5g. After updating to Android 12 /One UI4 Battery draining very fast.
 85% to 20% not last for 8hr with below average use.
60hz refresh display mode on ,Extra dim on ,Adaptive battery on, no location, dark mode is on,
Sync on.
Battery protection is on.
Overall enabled all bettery saving options, expect power saving mode.
85% to 20%:
85% to 34%
Need help to extend battery life
29 Comments
vaibhavraj
Bro i agree after 12 update it has been decreased a bit but I don't think that a bad backup. This backup is from 20 -85% which means the battery you are using is peak 4500mah(~4400mah) - 35% = 2825Mah. What else do you want from the 2825mah battery. So charge till 100% and below till 5% and then check it should last a day easily..And also it has 120Hz not 90Hz
Swaroop18
I am using 60hz display mode
And we should not charge till 100% and discharge till below 20% or 10% it will reduce bettery life.
20% to 90% charge is idle for good and long bettery life or durability.
Hence sumsung as bettery protection mode.
vaibhavraj
There is no 90hz mode.. if you are using mod or any app all are useless and please don't breach the security by any mod. You just purchased one of the safest device and breaching that by just a mod.
Swaroop18
There are two mode 90hz and 120hz motion smoothness
Ab_Heartsy
Expert Level 3
There's only two display refresh mode on S20FE5G, 60Hz & 120Hz. Are u using any app or to get 90?
Swaroop18
Oh sorry my mistake it's 60hz
You can let me if there is any app to get 90hz refresh, I don't know any.
owl123
I can see 60hz and 120hz. Where's the 90hz option?
Swaroop18
vaibhavraj
Bro i think please take some 👓. 🤣🤣its 60hz and 120hz
