05-23-2024 06:21 PM in
Galaxy S- Mark as New
05-24-2024 10:12 AM in
Galaxy SDear Samsung Member,
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
Note: To delete files or uninstall apps you no longer use, select a category under USER DATA. Then, tick items to select and tap DELETE or UNINSTALL.
Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
You can check the device in safe mode and for the same mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
