Sound issues
(Topic created on: 10-13-2025 11:26 AM)
Shilaja
After the recent update of one ui 8 on my s24 , the sound quality has decreased and there is no loudness from the speakers even while playing songs from the youtube the sound seems quite low and also there is no notificarion sound while receiving messages and other things , when i tried to change the notification sound every notification sound only vibrates . I even tried restarting the phone , removed all cache etc . Please fix the issue as soon as poosible , the sound output feels like it's coming from a 5k phone , it irritates a lot
3 Comments
cs_member10
Dear Samsung Member,
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
● Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
● Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
goodthings
goodthings
You're welcome to here.
