02-03-2026 12:22 PM in
Galaxy S- Mark as New
02-03-2026 04:33 PM in
Galaxy SDear Samsung member,
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Clear cache memory of a particular application: Settings > Apps > pick the app > Storage > Clear Cache.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
3. If you do not remember password, then advise to reset (Forgot password) your Google account.
Path: Settings> General Management>Reset>Temporary cloud backup or External storage backup>After backup tab on Factory data reset to reset your device to its factory default settings.
