Snapchat is not made for S24 or S24 is not made for snapchat ?
(Topic created on: 02-22-2024 06:18 PM)
yashvala13
Hello kiddos!! 😊
I recently moved to S24 from my OnePlus phone and switched my entire media application via Samsung Smart, and I installed Snapchat from the Play Store. 📱
But here, I see a back button issue; navigation back is not working properly in Snapchat. 🚫
1. While chatting and going to the main page is not working. 💬
2. Exiting the app is not working!!!
I don't know what the problem is here, but it's annoying for me. 😬
5 Comments
yashvala13
any solution?
yashvala13
haan buttons disabled hain usme nai aarhi dikkat
yashvala13
nai bro dono side se check Kiya but same issue !!
yashvala13
thik hai bro
cs_member10
Dear Samsung Member,
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
Note: To delete files or uninstall apps that you do not use anymore, select a category under USER DATA. Then, tick items to select and tap DELETE or UNINSTALL.
The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
Tap on Google Play Store app or Galaxy Store> Manage apps & device> Apps available to update> If you want to update apps individually, tap See details and then tap the Update button next to the app you would like to update.
Kindly contact the particular application helpline once, to make sure there is no issue from their end. You can reach the app developer through the email channel for which you please login to Play Store> select more option> select installed app> click on read more.
In case the issue still occurs, kindly report the problems with a log file and also share short videos or images of errors while occurring the issue for better understanding. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
