Smart calling (auto call back using same sim)
(Topic created on: 02-17-2026 12:35 PM)
RaviHegde
I am using a Samsung dual-SIM device and would like clarification on the “smart callback” behavior.
Requirement:
When I receive an incoming call on SIM 2, the phone should automatically use SIM 2 for the outgoing callback — instead of the default calling SIM.
Currently, outgoing calls are placed from the default SIM unless I manually select the other SIM.
Kindly clarify:
  1. Is there a built-in setting to automatically use the same SIM as the incoming call for callbacks?
  2. If yes, where is this setting located (One UI version specific guidance appreciated)?
  3. If not available, is this feature supported in any recent One UI versions?
Device Model: S21fe/ SM-G990B2/DS
One UI Version: 8.0
Region: India
Appreciate guidance from Samsung moderators or users who have successfully configured
cs_member10
Dear Samsung member,
We want to inform you that all devices have different and specific features depending on their hardware and software. As of now, the particular feature "Smart calling (auto call back using same sim)" you inquired about is not available on Samsung devices.
We appreciate your feedback regarding this matter and will take it into consideration for future updates.
If you have any other questions or need further assistance, please feel free to reach out.
