4 weeks ago in
Galaxy S- Mark as New
4 weeks ago in
Galaxy SDear Samsung Member,
As per your concern, we would request you to kindly perform the following steps to resolve your issue. However, we are taking your valuable feedback regarding this.
Galaxy device slow response issue: Kindly check the space on your device:
Path: Settings > Battery and device Care > Storage. To improve the device performance there should be sufficient space.
Clear app cache through Device Care: Tap on Settings>Device Care> Storage> Clean Now.
The clear cache memory of a particular application: Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
Is there any unnecessary application running in the background?
Kindly close the background running applications in the device (Tap the left side key & close the background running application).
Kindly uninstall that application by following the below steps and check once as the issue might occur due to third-party applications: Settings> Apps> Select the third-party application from Apps> Uninstall.
2. Galaxy device slow charging issue: https://www.samsung.com/in/support/mobile-devices/my-galaxy-device-is-not-fast-charging-how-do-i-fix...
Kindly follow the standard charging procedure. i.e. please charge the device in switched-off condition for 10 minutes.
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Kindly check if ''Multiple applications'' are running in the background of the device.
When running multiple applications, the processor processes more tasks and as a result, additional heat is released from the device. This happens with most electronic devices (even computers/laptops), including the devices of other manufacturers. Close all the background running apps when not using them.
Avoid usage of mobile phones during charging. Usage of the mobile phone when charging may cause slow charging issues. So we recommend you avoid the usage of the mobile phone while charging.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
