Slow Charging Speed In Samsung S23 Ultra
(Topic created on: 04-15-2023 05:20 PM)
SouvikPupun
Despite using Samsung Original 45 W brick & 5 amp thick cable, still the phone charges @ 65%/hr only when kept under screen off condition, this is far less than the advertised value..
#samsung #S23Ultra
19 Comments
SouvikPupun
bro, keeping it uninstalled still gives me the same charging speed, I have calculated manually also..
SouvikPupun
kaya tumhari charging speed isse tej hai? agar same raha to mujhe fikar karne ki jarurat nahin, Samsung jarur software update dekar fix kar dega.
SouvikPupun
still you've got better charging speed with 25W samsung brick, so there must be some issues which require attention.
SouvikPupun
which statement of mine seemed 'attacking' for you Mr. Sarkar? whereas I find the exact rude response from both of you but choose to remain silent..
let me clear the confusion, the topic of my discussion was slow charging, and nobody asked you two to come and comment on my post..and dear Sayan, you kept talking about third party apps, what's that got to do anything about charging speed? if u speak irrelavant, I will stick to my point na?
Sáyân15
1 sec, when did i abuse you to or talked to you rudely? 🙄
Just tell me what is wrong or what wrong i said to you, & if you really think i was rude or my behavior was, then apologies for that. If you really want to know your charging time then start a stopwatch when you plug in the charger for charging to get 100% accurate results. These battery apps like Accubattery & other apps are just gimmicks but nothing else. They provide wrong information & most of us believe in them & that shouldn't be done.
Anyways, I'm deleting my all comments & replies. Goodbye & better see you never...
Chinmay96
Did you check if Fast charging option is Turn on or off.
If it is turn off kindly turn it on
SouvikPupun
I've checked the option and its turned on already
VISHNU1700
I HAVE SAME ISSUE ,I HAVE 3 S23U AND 3 CHAGERER BOTH HAVE SAME ISSUE
SouvikPupun
did u feel it was okay earlier and the problem got triggered out of nowhere by the latest update?
