Signal issue
(Topic created on: 10-09-2024 09:09 AM)
AdityaSharma55
After updating s20fe security patch,the network signal gone . I restart mobile multiple times but it didn't work as well as the airplane mode. It's just a security path and signal gone in a flagship level device. Then how to solve this issue.
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
6 Comments
samnull
You can try changing the sim slot or reinserting it which will solve your problem temporarily, but as its caused by the software update it wil only be fixed by the software update
goodthings
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also restart your's device without any Sim in slots also interchange Sim in slots also turn off power saving mode then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
I tried all this setting but then network not come.
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, we would request you to kindly visit this mentioned link to resolve your Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Compser> Select error report> select the appriopriate issue category> Type your query and send.)
