Should I use FHD+ or QHD+ resolution on my S10? Does using higher resolution affect battery usage?
(Topic created on: 03-05-2021 11:00 PM)
VaiPin7
I heard that using either resolution doesn't reduce battery usage as long as the display is 60hz, but I want to know from you all.
8 Comments
rojon
Higher refresh rates and higher resolution generally cause battery drain but a higher refresh rate will have the highest impact.
Ehsank
see dear as my opinion don't think so much about battery just enjoy your feature, and how long you use ur camera to record this is not daily routine i guess
btw yes 60hrtz will save more battery compare to high rfresh rate
Not applicable
I think he was asking about display resolution and not camera.
also there is little to no change in battery drain imo. I'm using wqhd though
Ehsank
ohk thanks 😊but answer will be same 😁
Bro, use your device to the fullest,if feature is there utilize it,forget about battery,definitely it affects battery but not that much..👍🙂🙂
Notadeveloper
Use 60Hz QHd+, use your device to fullest. You paid for it then, you use it fully
User28
Correct.
If satisfied with my response then click at 3 dots near my above comment and accept it as solution to help others 👍
