05-02-2025 03:30 PM in
Galaxy SSolved! Go to Solution.
2 Solutions
05-02-2025 09:53 PM in
05-03-2025 11:52 AM in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
If the issue persists and regarding widget Issues, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send).
05-02-2025 04:16 PM in
Galaxy S- Mark as New
IMPORTANT:
• For this:
