04-08-2026 02:59 PM (Last edited 04-08-2026 02:59 PM ) in
Galaxy SSolved! Go to Solution.
04-08-2026 03:15 PM in
Galaxy SThe issue you are experiencing with YouTube Music and Way2News is likely due to Audio Ducking or Multi-sound conflicts introduced in recent security updates. Since "Separate App Sound" is off, the system is struggling to balance the volume levels of two apps running simultaneously.
Please follow these steps to stabilize your audio experience:
🛠️ Step 1: Install & Configure "Sound Assistant" (Highly Recommended)
Samsung has a powerful module in the Galaxy Store called Sound Assistant (part of Good Lock). This app gives you individual control over every app's volume.
Download Sound Assistant from the Galaxy Store.
Open it and turn ON the feature called "Multi-sound".
Select "YouTube Music" or "All Apps". This prevents one app from lowering the volume of another app when both are open.
🛠️ Step 2: Disable "Media Volume Sync"
Sometimes the Bluetooth or system volume syncs incorrectly with specific media apps.
Go to Settings > Sounds and vibration > Volume.
Tap the three dots (⋮) at the top right corner.
Check if there is a Media Volume Limit or Sync option and reset it.
🛠️ Step 3: Clear "Media Storage" Cache
Since this started after a security update, the system's media controller might have some corrupted cache.
Go to Settings > Apps.
Tap the Filter/Sort icon and enable "Show system apps".
Search for "Media Store" or "Media UI".
Go to Storage > Clear Cache.
Do the same for the YouTube Music and Way2News apps.
🛠️ Step 4: Check Dolby Atmos Settings
Dolby Atmos sometimes tries to "equalize" sound based on content, which causes a sudden "blast" or "drop" when switching between music and news.
Go to Settings > Sounds and vibration > Quality and effects.
If Dolby Atmos is set to "Auto," try switching it to "Music" or "Voice" specifically, or turn it off to see if the fluctuation stops.
✅ Expert Tip: Samsung Community mein sahi aur sateek jaankari share karna hamara maksad hai. Agar aapko ye solution helpful laga aur aapka issue resolve ho gaya hai, toh please is Comment ke baju mein bane three vertical dots (⋮) par click karke 'Accept as Solution' select karein. Isse hamari mehnat ko appreciation milta hai aur community ke baaki members ki bhi help hoti hai! ⭐⭐⭐⭐⭐ 💙🚀
04-08-2026 03:44 PM (Last edited 04-08-2026 04:46 PM ) in
Galaxy S- Mark as New
04-08-2026 04:25 PM in
04-09-2026 06:53 PM in
Galaxy SDear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
04-09-2026 07:16 PM in
