Screen Recording problem
(Topic created on: 10-30-2023 11:44 PM)
Apollyon369
I'm using S23 ultra
On screen recording while gaming I'm facing frame drops😬
Is there any solution
2 Comments
ipratikbhoir
In upcoming Android 14 One UI 6 you will be able to do screen recording upto 1080p/FHD 60FPS so i guess won't be issue for you.
cs_member10
Dear Samsung Member,
As per your concern, if you are facing an issue with the sprat game, we would request you to kindly contact the respective application helpline they will provide you with the exact information regarding this and if you are facing the issue with every application time, kindly report the problems with a log file.
To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
