Samsung s25 ultra bluetooth issues
(Topic created on: 04-19-2025 05:02 PM)
AJEYEG
My new samsung s25 ultraa when paired to music devices like car music or headphones is giving the worst music experience.  Despite tryjng all available options checking various sound optimisation seems to worsen the music experience.   I have tried it with the best of the best speakers out there and the bluetooth experience is worst.  Henceforth the bluetooth issues need to be resolved
3 Comments
Dr_Vivekvh
Not facing such issues. Daily using Bluetooth with my JBL pulse, Sony HT and car music system...try to update your phone or go to samsung service center.
LordXesus
Turn on dolby, and if theres a higher codec support then use that ...
cs_member8
Dear Samsung member,
As per your concern, we would request you kindly perform the following steps to resolve your issue.
● Reset app preferences: Settings > Apps > More option > Reset App Preferences.
● Kindly try to connect your device with "other devices" and check.
● Clear cache: Settings > Apps > Menu > Show system apps > Search and type "Bluetooth" > Bluetooth > Storage > Clear cache > Clear data > OK.
● The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
● Reset settings: Settings>General Management>Reset> Reset all settings to their default.
● Reset network settings: Reset Wi-Fi, Bluetooth, and other network settings to their default.
