Samsung s25 ultra battery drain
(Topic created on: 03-26-2025 11:54 PM)
vishnucruze
Before update 9hours but
After update battery drain issue...
Daily routine 90%
DISPLAY -FHD
120FPS refresh rate
5G DATA
Any solution samsung users.....
cs_member10
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
