Samsung s23 ultra ..Netflix HD and HDR 10 ,Dolby functions are not working
(Topic created on: 09-12-2023 12:27 PM)
V1991
Samsung s23 ultra ..Netflix HD and HDR 10 ,Dolby functions are not working .still they didn't given. still waiting UI6 update
11 Comments
Are you using OneUI 6 beta?
Devv_007
Dolby sound is supported but dolby vision isn't.
Ravi0883
Dolby Vision is not supported any samsung device
Devv_007
Yes,thats what I have written.
Devcool
Here is my s23 ultra screenshot...it's supports all codec except dolby vision which is obvious 😉 Screenshot_20230912_135356_Netflix.jpg
Yeah even mine is supporting all codecs except dolby visionScreenshot_20230913_081244_Netflix.jpg
Yep I have the same issue. Not only for Netflix but downloaded content using MX Player Pro as well. HDR10 and HDR10+ looks way dimmer and has dull colors. SDR looks very very bright and colorful in comparison.
They really need to fix this in future firmware updates. There must be a way they could replicate this issue.
(It could be an international version/gsm unlocked problem only).
Please Samsung fix this issue. Thank you.
cs_member10
Dear Samsung Member,
Greetings from Samsung Customer Support
As per your issue, we want to inform you that Dolby Vision is not supported on your device and One UI Beta 6 is enrolled now in India. So kindly stay active on the Samsung member's application to update your device in beta. For another issue kindly report the problems with a log file. Please share the device log file within 15 minutes of the issue occurrence by using the error report option via the Samsung Member application. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Samsung Customer Support.
mg61155
Bro same problem on my s23 ultra what to do?? Help anybody?
