Samsung s21 plus battery drain
(Topic created on: 10-13-2021 04:44 PM)
mkunal
Beginner Level 5
Dear samsung team
Its almost 2 months to use samsung s21 plus in this time i was noticed battery drain problem ,without any heavy game play or movies the phone continue drain battery...its a very sad thing...above 60k mobile doing bad performance in my opinion..next time i should not go with samsung flagship phone.
4 Comments
Green_Grass
How many times you will post same thing?
I already told Samsung will not read your message here.
And your account will ban if you post same thing again and again.
Not applicable
It will be solved by software update.Its happening to other devices too september security patch solved the problem but on some devices the issue still persists.If found helpful pls accept as solution
kosika
Yeah , samsung doesn't value its customers. Either low budget phone or flagship phones problems are common
Dear Samsung Member,
We acknowledge your query and apologize for the same. To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
