Samsung s10 is showing cable charging
(Topic created on: 05-31-2020 02:41 PM)
kpu
S10 is not showing fast charging
When I clear cache data and restart phone then only first time it shows fast charging
When i remove the cable and replugged it then it again shows cable charging
Weird problem
21 Comments
Not applicable
did u try to enable it in device care?
kpu
Vaishu1303
Yes happens with me too.
kpu
any solution
Not applicable
might be a bug or something...
Aashish
Expert Level 4
Just turn off charger and turn it on again.
kpu
nothing happens
Aashish
Expert Level 4
With a different cable?
AravindanR
This some times happens to me. I usually unplug and plug the charger again. Then it will work.
