Resolved! Solved
Samsung performance issue.
(Topic created on: 01-08-2025 12:34 PM)
samsungexperrt
Hello there folks! I hope everyone is doing real good.
Recently, after the December security update I have noticed a certain issue on my S22. The on screen time on my S22 has reduced by almost 15-20% of what it used to be before the december update. Earlier it was around 5h 15 min hours of screen time at 100% charge(approx) which is now at 4h 20mins(approx). Tell me if any one else also facing the same issue...
Screen time screenshot
Wodehouse
It seems like you're not alone in experiencing this issue. There are other Samsung Galaxy S22 users who have reported a similar problem with reduced screen time after the December security update.
This update was released to fix several security issues, including some related to Exynos chips, but it's possible that it may have introduced some performance issues.
Some potential causes of this problem could be:
- *Software glitches*: The update might have introduced some bugs that are affecting the phone's performance and battery life.
- *Power management issues*: The new update might be managing power differently, leading to reduced screen time.
- *Hardware-related problems*: Although less likely, it's possible that there's a hardware issue with your phone's battery or charging port.
To troubleshoot this issue, you can try:
- *Restarting your phone*: Sometimes, a simple reboot can resolve software-related issues.
- *Checking for software updates*: Ensure you're running the latest software version.
- *Calibrating the battery*: Let your phone's battery drain to 0% and then charge it to 100% to calibrate the battery.
- *Resetting phone settings*: Reset your phone's settings to their default values.
If none of these steps resolve the issue, you may want to visit a Samsung authorized service center for further assistance.
Please do check these links
https://r2.community.samsung.com/t5/Galaxy-S/Samsung-performance-issue/td-p/17919100
https://www.androidheadlines.com/2024/12/galaxy-s22-series-now-receiving-the-december-2024-security-...
https://www.sammobile.com/news/galaxy-s22-december-2024-security-update/
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
4 Comments
Wodehouse
Thankyou somuch for the input. Imma check all the stated instructions and let you know if it helped...
goodthings
Please like if it's the same line you put onto every post👏😊
