Samsung network issue(please help)
(Topic created on: 04-17-2025 01:25 AM)
shri--07
I have been using s25 ultra since a month.
It shows emergency calls only once i go out of my wifi coverage.
It basically means no sim card installed as the signal bars above are that of the signal strength with the nearby tower irrespective that whether sim is there or not.
I need to turn on/airplane mode for that.
Any permanent solution
8 Comments
goodthings
Kindly reset factory data with backup again then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
shri--07
I have done fsctory reseg but it didn't work
cs_member10
Dear Samsung Member,
As per your concern, you have already done the possible troubleshooting steps and the issue remains unresolved, we kindly request that you visit our service center. Our technical team will be able to inspect your device physically and provide you with detailed information and assistance.
You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
spa2025
Same here
shri--07
Hello
Get your sim card changed,
It will solve the problem
I did it and it is now working fine
spa2025
I am already done same process but same problem is showing
shri--07
I am also facing the issue again
