04-25-2024 11:43 AM in
04-25-2024 04:26 PM in
Galaxy SDear Samsung Member,
As per your query, we want to inform you that this is not a bug or issue, It happens due to the Adaptive brightness feature enabled on your Samsung device, this feature allows the touchscreen to automatically adjust its brightness based on the surrounding environment, you can follow the below steps for resolve your device issues. However, we are taking your valuable feedback regarding this.
① Change the display mode to ‘Light’ mode. (Settings > Display > then select the ‘Light’).
② Alternatively, Adjust the display brightness a little bit brighter. (Settings > Display > adjust the Brightness to a brighter level).
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
04-25-2024 05:21 PM in
Galaxy SStill the problem I am Facing
Check once in any S24 Ultra Mobile in Outdoor Sunlight...
I tried in 3 Mobiles, Same problem in all mobiles
05-26-2024 04:31 PM in
Galaxy SI am very premium coustmers of samsung for more than 20 years but i am giving this in writing .i with my s22 ultra upated software after mobile setup till 100 % when optimisng finished when switch on the phone green line came after line i shut down the phone 2-3 times and it was biggest fault that i upaded my phone
Dont parchese samsung S seris phone
S22 ultra s23 ultra s24 ultra all model probleams
Dont update one UI version 6.1
