Samsung S24 Ultra Screen Display Issue in Sunlight
(Topic created on: 04-24-2024 04:45 PM)
RAMULTRA24
Hi All,
Try using Samsung S24 Ultra in Sunlight just for 5 Minutes, The Mobile is Over Heating & Screen light is Dimming and becoming not visible clearly in Sunlight ....
This is very Serious Issue in Samsung S24 Ultra Flagship Mobile...
Samsung need to Fix it as early as possible....
Every Samsung S24 Ultra user try this and Raise this Issue & Complain over this
7 Comments
cs_member10
Dear Samsung Member,
As per your query, we want to inform you that this is not a bug or issue, It happens due to the Adaptive brightness feature enabled on your Samsung device, this feature allows the touchscreen to automatically adjust its brightness based on the surrounding environment, you can follow the below steps for resolve your device issue:
① Change the display mode to ‘Light’ mode. (Settings > Display > then select the ‘Light’).
② Alternatively, Adjust the display brightness a little bit brighter. (Settings > Display > adjust the Brightness to a brighter level).
However, Kindly perform the following steps to resolve your heating issues. However, we are taking your valuable feedback regarding this.
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
RAMULTRA24
All the above we tried
But No Use👎
Just now I tried in outdoor Sunlight within 2 minutes Screen is Overheated and become dull Screen....
It's a big Issue, Kindly fix it
ROZAJMERI
I am a pure sumsung coustemer from 2000 when gsm phone with entina till 2024 i am still using sumsung in the year but now after using sumsung from 20 years i am never dissappoint from sumsung but now i am very dissapoint to say that i own and trustable company has fraud me .my sumsung s22 has a got a green line after software upate i am very sad to say that samsung has disappoit me after using sumsung from 20+ years this is sad moment for my life i request you to replce or repair my device because i could not accept this kind of things with pure sumsung couatmer and it is not only me but many other coustemrs have this problem and i am very sad to say that if this kind of behavior contines we people from samsung family needs to leave the samsung family and use other phones we are not at all happy to leave this company at all and this is not are fault at all its your company fault and only you are 100% responsible for it if the software is not ready to use company should not upade the mobile company should cheak the upade with responsiblity in upate 16.1 One UI Version problem i was using m200 galaxy Y galaxu y duos R200 galaxy grand ,grand2,j7,j6,,s3,s3 mini ,A50,A53,A52 wifi 6 S7 Mini , S5 , Galaxy F ,Samsung Guru keypad mobile and many more but after many years i do not rember some of them but i am never dissapoint with any of them but this s 22 ultra has got a green line after upade . But i am very sad to say the samsung is nowdays is not giving value to coustmers but giving importance to money and thinks to make company more profjtable we the people of india takes coustemers as god and happiness is only we need and try to stasify it thats all we dont give the pripority to money on coustmers we are not willing to defame the company but my friends were telling not to buy samsung and my trust on this comoany has been removed
I am very premium coustmers of samsung for more than 20 years but i am giving this in writing .i with my s22 ultra upated software after mobile setup till 100 % when optimisng finished when switch on the phone green line came after line i shut down the phone 2-3 times and it was biggest fault that i upaded my phone
Dont parchese samsung S seris phone
S22 ultra s23 ultra s24 ultra all model probleams
Dont update one UI version 6.1
RAMULTRA24
The Display is very very Poor in S24 Ultra when Compared S23 Ultra even in Outdoor & Indoor......
Immediatly Samsung need to fix Poor Display Issue in S24 Ultra Flagship Mobile....
ROZAJMERI
Yes sure
Members_RKffXOx
Beginner Level 3
I have the same issue.
I can't use my phone outdoors. The only thing I see is my glare.
RAMULTRA24
Inreported this issue manytimes to Samsung & also raised jobsheet in the Samsung service center also But Samsung is not Fixing this issue
