Samsung S23 Ultra Battery: 6 Hours on 5G – Good Enough or Not?
(Topic created on: 12-03-2024 11:05 AM)
yebhoi
I've been using the Samsung S23 Ultra for a month, running it on 60Hz refresh rate and FHD+ resolution. My daily usage includes Instagram Reels, YouTube Shorts, about 30 minutes of YouTube videos, and 20 minutes with the camera, all on 5G cellular data.
With this setup, I’m getting around 6 hours of screen-on time. Considering the power demands of 5G, do you think this battery performance is good, or should it be better? Let me know your thoughts!
10 Comments
You can get more than 6 hours screen on time ie disable mobile data in standby and reduce usage of camera while turning on mobile data which drain most battery
yebhoi
That’s ok or not bro
For me you could get more than 6 hours screen on time, since I get around 2 day of battery life sometimes more than 2 days.
yebhoi
What is your usage or display hz or apps usage or resolution or sot each and every thing can you please explain me take your time to answer
I used 60 hz display, power saving mode always enable to disable 5g network, resolution always set to qhd+, i don't consider screens on time since I consider standby total time around 80 % of charge maximum, app are restricted almost all app to deep sleep, enabled adaptive battery, using vivid mode in display, using dark mode, i don't use mobile data and location and Bluetooth in standby.
yebhoi
Bro can you tell me which apps use most or screen on time
I can take an idea.
yebhoi
And thanks bro
TechieUS
Along With screen time and refresh rate, it is also important to count for the brightness of the screen display.
yebhoi
So it's good or not
