Samsung S23 FE Battery Drain
(Topic created on: 07-08-2024 10:32 AM)
Reneshravic
I'm using Samsung s23 fe for 6 months. I am using exynos version but the battery backup is so poor if I am doing video call, have to charge twice a day. Regret buying this phone
3 Comments
ayyan_156
Same
Samsung_specialist
Here are some tips to improve battery life on your Samsung Galaxy S23 FE:
1. Adjust Screen Brightness
2. Close or disable apps running in the background that you're not actively using.
3. Enable Power Saving Mode
4. Review the battery usage stats in your device settings to identify apps or processes consuming excessive battery power. You can then take action to optimize or uninstall these apps.
5. Ensure your device is running the latest software version provided by Samsung, as updates often include optimizations and improvements to battery performance.
6. Turn off features like NFC, Bluetooth, and location services when not in use, as they can drain battery power unnecessarily.
7. Adjust the sync settings for apps like email, social media, and cloud services to reduce the frequency of data syncing, thus conserving battery power.
Reneshravic
This doesn't work at all, twice daily you have to charge the battery . Battery is biggest concern in Samsung phone
