|| Samsung S23 FE 5G - Charging issues ||
(Topic created on: 10-09-2024 12:39 PM)
Chandrakant_Rana
Dear Samsung,
I recently bought Samsung s23 FE 5G and mostly all day I need to plug this to charging
It is heating, draining too fast and slow charging as I'm using Samsung original 25watt charger and it shows fast charging but not doing the same.
Can I please check this
I'm using Samsung first time and having very bad experience.
11 Comments
RICCMMAN
Bakra 🐐
RICCMMAN
Samsung s23 fe or any fe variant buyers = 🐐
goodthings
Kindly charge your's device in cool atmosphere also during charging turn off internet also reset all settings of your's device in general management settings also turn on superfast charging too, then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
RICCMMAN
Fe variant actual problem is their exynos. 🥵
I am using s23 which has snapdragon it's goes upto 46° outside and 35° - 41°C inside even in AC room. 🥵 #Samsung #GalaxyS23 #Exynos #Snapdragon
Exynos9611
cuz 6.1 inches display phone cant fit more cooling equipments
RICCMMAN
I knew it before ordering! 🔮 #clairvoyant #fortuneteller
Ritwiksondhi
S23fe has documented heating and battery issues. You need to use it cautiously.
