Samsung S22 facing Camera and Camera UI lag
(Topic created on: 12-09-2024 11:42 AM)
this_is_mukulthakur
Hi,
Device - Galaxy S22 5G
I am facing camera UI lag while:
Shifting cameras from 1x to 3x;
Switching capture modes (e.g., Photo to Video/Portrait, and all);
Opening camera settings;
Opening the gallery via the camera app.
I don't want to update my device because pink lines are appearing for other users.
Please advise on how to fix this.
3 Comments
goodthings
Please clear catche and clear data of this app and reset camera settings also reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also optimize your's device in device care too then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
● Reset the camera settings: Home screen tap on Camera>Settings>Reset settings>Reset.
● Clear camera application data: Apps>Camera>Storage>Clear Data
● Check app cache: Settings > Apps > Camera> Storage > Clear Cache.
