Samsung S20FE 5G - Battery
(Topic created on: 05-01-2022 11:01 PM)
Ramprakashprmurali
*****Purely my view*****
After the April update, my Battery is doing magic. Let me update the status once again by tomorrow.
Refresh Rate : 60
9 Comments
Šunil
Waiting for updates
Update 1 : Charging at 5%.Screenshot_20220502-001509_Device care_19399_1651430747.jpg
Sáyân15
6 hrs of SOT is nothing extraordinary considering 60hz
If these would be the stats with 120hz then i would say, it's not bad & neither gd also, it's average in my frank opinion...
But question is why use 60hz? 🙄
Common dude... when you're paying a premium price, you should get most out of your flagship device too...
Me personally the day i got my device, i never switched to 60hz
Always using 120hz & the thing is i can't go back to 60hz... coz using 60hz after 120hz seems like the screen is lagging too much
Anyways, use 120hz then share your stats again 🙂
Sure, will update it tomorrow then🤘🏼
Sáyân15
Will be waiting for the stats😄
SHIVAFUSE
Iam having an issue of sudden close of my running app and sudden switch on the Bixby app I have got the security patch so if I installed will it help in that or will it remains same please advice
Today!
Refresh Rate : 120 Screenshot_20220504-220559_Device care.jpg
S-Dey
How old is your S20 FE 5G? The battery life seems very bad to me at 120 Hz.
Yesterday and the Day Before
Refresh Rate : 60Screenshot_20220503-235300_Device care.jpgScreenshot_20220503-012053_Device care.jpg
