Samsung Galaxy S23 Earpiece Sound Crackling Issue
(Topic created on: 03-18-2024 11:35 PM)
Abhishek113
Hey,
I just got replaced my S23 for a strange earpiece and speaker sound crackling issue. But I felt like a same but minor crackling sometimes in the new unit too. What's this Samsung? Is it quality control issue or is it an issue with all S23 units? S23 users please write your experience here.
10 Comments
Sayam_Hossain
No, it's an electric product, and electrical things can have disputes....
ankitmon
What are you even talking about. Go outside and try breathing oxygen.
Abhishek113
Abhishek113
It needed dispute and got it replaced but experiencing the same in the new unit too..
SPYDER_001
No problem with me
Abhishek113
But I'm experiencing this in the replacement unit too. 🫠
Was searching the forum and came to know that many people are facing similar issue and frustrated
SPYDER_001
Lucky me then I guess 😅
Abhishek113
I hope flipkart refunds me this time and wanna say bye-bye to samsung now..
cs_member10
Dear Samsung Member,
Disconnect anything plugged into the headphone jack like, a selfie stick, headphones, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
Clear Sound Picker data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Picker> Storage> Clear data of Sound Picker.
Clear Sound Alive data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Alive> Storage> Clear data.
Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
