04-17-2024 10:11 PM (Last edited 04-17-2024 10:17 PM ) in
Galaxy SSolved! Go to Solution.
- « Previous
- 1
- 2
- Next »
04-18-2024 10:02 AM in
Galaxy SDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue. However, we are taking your valuable feedback regarding this.
Remove the screen protectors and cover from the device once and check the issue after restarting the device.
Press the power and volume down keys simultaneously for a few seconds.
Check space availability: Settings > Device Care >Storage.
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
Note: To delete files or uninstall apps you no longer use, select a category under USER DATA. Then, tick items to select and tap DELETE or UNINSTALL.
Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
3 weeks ago in
Galaxy S- « Previous
- 1
- 2
- Next »
