šŸ’„Samsung Galaxy S20 Ultra vs S20 Plus vs S20: Charging speed comparisonšŸ’„
(Topic created on: 04-01-2020 11:51 AM)
Abhy
ā˜…ā˜…
All three new Samsung Galaxy S20 series of phones come with a very fast, 25-watt charger included in the box, but since there is a difference in the actual size of the battery, you might be wondering which Galaxy S20 phone actually charges faster.
In the Galaxy S20 series charging comparison, all three phones are tested with the included charger in the box, and the charge is measured at equal intervals.
You might be surprised with the results, but before you see them, here is a quick overview of the battery specifications for each Galaxy S20 model:
  • Galaxy S20 Ultra: 5,000mAh battery, 25 watt charger in the box, max charging speed is 45 watts (you need a separately purchased charger to achieve it)
  • Galaxy S20 Plus: 4,500mAh battery, 25 watt charger in the box, max charging speed is 25 watts
  • Galaxy S20: 4,000mAh battery, 25 watt charger in the box, max charging speed is 25 watts
With this in mind, all three models have been plugged all three were completely drained, and it's time to see which one is the fastest to recharge.
25w Charging
And there you have the results with a surprise: even though all three phones use the same 25-watt charger, the Galaxy S20 Ultra which has the biggest battery which should theoretically take longer to recharge, it actually finishes first in just seconds short of 1 hour.
Overall, these are very fast speeds that will allow users to get a quick 30 minute top up during the day and have enough juice for the rest of the day in case they forgot to charge their phone overnight.
We have seen Chinese companies push the charging speeds to the extreme and some recent phones already charge up fully in less than 40 minutes. The new Galaxies are not quite as fast, but if you are looking for a more secure charge that won't tax the battery as much, Samsung's solution might be preferable. We are yet to see long-term studies showing the effect of extremely fast charging on long-term battery health.
45w Charging
The benefits of using a 45W charger are mostly seen if you give your phone a quick top up for less than 45 minutes, if you are looking for a full 100% charge, the difference in speeds is basically non existent as the 45W charger and the 25W charger both slow down towards the end of the charging cycle and finish in the same amount of time.
So there you have it, your ultimate guide to the Galaxy S20 series charging speeds.šŸ‘šŸ‘Œ
5 Comments
Not applicable
ok ok to me phones ke liye inta zada charging speed
Abhy
ā˜…ā˜…
5000mah full charge in 1hr... that's commendable I feel
AřpĆ®t
nice information...
Abhy
ā˜…ā˜…
Thanks Arppit
Drosh
charging is slow in s20 plus after the update...it shows 1 hr 10mins but it takes almost 1 hr 30mins to fully charge
