Samsung Firmware Downgrade process !!!
(Topic created on: 03-30-2024 02:53 AM)
Sayam_Hossain
I have shared the downgrade  process for samsung smartphones.
Follow for more tips, and if you have any questions you can ask me as well.
Here you go...
6 Comments
Have you face any problem after downgrading one ui 5.1? And do you feel the overall perfirmence is significally better compare to one ui 6 or 6.1? And will you able to ota update via samsung server in future?
Sayam_Hossain
Obviously I will get OTA updates, I haven't seen any issues, Just got the old days battery backup and great camera performance back.
Christof19
You would not have installed any security patches after the OneUI 6.0 update, cause then you can never downgrade back to 5.1. If SW.Rev number higher in the upgrade you can never downgrade to a lower version.  Please provide details of last 6.0 build before you downgraded then we can accept your solution.
Sayam_Hossain
My device was fully updated to 6.1.
Last version was - S918BXXU3CXCF
Christof19
Your post does not apply to all devices and firmware you should update the post title or it is misleading.👍
Sayam_Hossain
I am from Indian, and this post is relevant to all Indian S23 Ultras.
