Samsung 45W charger charging in normal speed
(Topic created on: 10-22-2024 11:47 PM)
Pradeep1428
I own a sammy S24 Ultra, i brought a 45W samsung charger along with the device. I have been charging the device with the same charger from the day 1 and mobile used to charge in Super fast 2.0 mode with Violet circle light while plugging in. Suddenly from this morning when i charged my device i noticed that it is charging normally with green colour circle light while charging! I tested it with my Samsung s20 FE its charging in super fast mode, So the charger is not faulty.
I doubt if its a software problem or is there some settimgs in the device which got changed . The purpose of buying this charging brick spending huge money is not resolved.
Dear community member and Samsung care you have any update out idea to resolve this please respond back ?
16 Comments
Akshay_Sharma
Go to in battery setting and enable fast charging... thank me latter
Pradeep1428
It's already On buddy! But thanks for taking your time to reply!🙏
Akshay_Sharma
Um after that .. which circle is showing.. while charging.....green or violet 😐?
Pradeep1428
It's showing green! 😮
I found some response and even reset all the setting ! But in vain it did not work!
Akshay_Sharma
Pradeep1428
This is what I was getting previosuly but now it is in green!
Akshay_Sharma
Initially, I was also facing this problem but when I used Samsung's original 25 watt PD charger, then fast charging got enabled in my Samsung s24 device and if you use any other brand's fast charger, then fast charging will not be enabled, you will have to use the original charger only
Pradeep1428
I am using samsung brand charger which was purchased in samsung store! This is a sudden issue?
Akshay_Sharma
Then I think it is a software issue.....
send feedback to Samsung....
