SOLUTION: DOWNLOAD STUCKED PROBLEM SOLVED
(Topic created on: 04-23-2025 08:32 PM)
techpanti
If you are facing problem in downloading stucked at certain %. Here is the solution -
👉Tuen off Data/wifi untill it shows cannot download.
Then again turn on the internet and try to download and it should start from the beginning, if doesn't continue the same proces several time. It will work. It worked for me.
Enjoy
3 Comments
Nilesh_Shah
Congratulations..
Give us detailed review once you settle down with the update.
techpanti
Kuch nahi hai bhai just overhyped
SubhadipDas94
I've completed by doing pause and resume for 3 times
