SAMSUNG S23 battery " Learning usage patterns"
(Topic created on: 07-10-2024 01:01 PM)
TAFAA
I bought Samsung s23 on 8th July and today is 10th July. Since 8th I'm observing my "Battery" tab in settings showing "Power saving. Charging", although my phone is charged and not on power saving mode.
With that when I click on "Battery" tab, it says "Learning usage patterns" for straight 2 days now.
I don't know how long will it take to learn usage pattern or if my Device has battery issue and should visit a service center.
Please suggest!
18 Comments
TAFAA
Yup! I'm getting 1day 2hrs approx. on normal usage
Whoa. Its the base s23? I unboxed my phone yesterday . But the battery gave around 4-4.5 hours sot from 100-20. And it drained at unusual situations. So it will get better once it adapts? I'm using at 120 hz , and switching between 5g and wifi.
TAFAA
Yeah it will learn to your usage patterns and adjust. Change battery protection mode to adaptive or maximum, mine is on adaptive and I also use 120 hz while switching 4g and wifi
I heard people say that the difference won't be that huge and after seeing my crazy battery drain i was shocked 😭😭
How much SOT do u get daily on an average use?
TAFAA
4-5 hrs
I see. But did the standby battery drain get better after learning the usage? Because I got around 4hrs Sot from 100-80. There are cases where ppl got 6 hours ish battery for almost the same amount of usage. The main issue for me rn is the abnormal drain when on standby ( even for an hour) nd for light tasks too. Apart from that everything else is perfect about the phone.
TAFAA
Give it a week. Everything will come in line
Alright. Thank you!
